Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Brakes and Suspension
Old 12-15-2017, 04:54 PM   #1
wayfastwhitey87
wayfastwhitey87's Avatar
Larger power steering cooler.
I've been looking to get a larger power steering cooler to replace the "hairbrush" that the cars come with stock. With a little searching it seems like a lot of guys are going with the B&M supercooler part number 70255. Which seems like a near direct fit, with the exception of drilling a couple holes.
Does anyone on here have this set up? Or another cooler that fits the bill better?
wayfastwhitey87 is offline   Reply With Quote
Old 12-17-2017, 03:52 AM   #2
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
I bought a setrab race cooler to add. Are you having heat issues?
"You'll eventually send me your diff, send it the first time, not the second or third time! This will prevent thousands of dollars going to waste." STANDARD LIMITED LIFETIME GUARANTEE IS STANDARD ON ALL BUILDS.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 12-18-2017, 01:23 PM   #3
wayfastwhitey87
No heat issues yet, more of a preventive move. Plus I'm looking to replace the reservoir with a billet one and I figured since I'm going to drain the old fluid out it would be the time to do a bigger cooler.
Which Setrab cooler did you go with?
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
