Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Sound Systems and Electronics
Old 12-30-2010, 07:16 PM   #1
Robofuzz
Robofuzz's Avatar
Send a message via AIM to Robofuzz
Converting to 06 steering wheel radio controls discussion
Very cool! Where'd you get the clock spring and controls?
Robofuzz is offline   Reply With Quote
Old 12-30-2010, 07:18 PM   #2
I found them on EBAY
tom's2005gto is offline   Reply With Quote
Old 12-30-2010, 07:26 PM   #3
Robofuzz
Robofuzz's Avatar
I'm going to check with HP Salvage (sponsor) and see if they've got some 2006 GTO's. I've been wanting to do this mod for a long time.
Old 01-06-2011, 06:10 PM   #4
ram09
The Anheuser-Busch Mod
ram09's Avatar
Here is the link back to the original How To:
http://www.gastiresoil.com/showthread.php?t=2293
Please discuss in this thread and not in the original How To, that thread is for information purposes only.
Thank you,
Randie
"A fairy tale starts out once upon a time, a fishermen's tale starts out with: This is no bullsh*t." Capt Phil Harris
2004 Ghost White/Red M6
1 0F 1
Mods to date:
K&N CAI, SLP MAF Sensor, 3in SW Catback w/chambered muffs, BAER 13in brakes front & rear, TB Coolant Bypass, 160 degree thermostat, Royal Purple motor, trans, & rearend oil, black tails
ram09 is offline   Reply With Quote
Old 07-17-2011, 06:38 PM   #5
Robofuzz
Robofuzz's Avatar
Just finished up on this mod. Tom's how-to is right on the money! Very easy modification when you have a guide to follow. Thanks, Tom!!
Old 11-07-2016, 07:08 AM   #6
Bradlyj8GTO
Bradlyj8GTO's Avatar
Clock spring
Old thread, I know. Anyone have the part number for the clock spring? Rockauto list one that says new style for 69 dollars. Just want to make sure its the right one and will power the lights. Thanks.
http://www.rockauto.com/m/mobilecata...parttype=10480
Click image for larger version
Bradlyj8GTO is offline   Reply With Quote
Old 03-24-2017, 11:15 AM   #7
Bradlyj8GTO
Nobody? No?
Old 07-09-2017, 07:12 PM   #8
Robofuzz
Robofuzz's Avatar
Sorry, just saw this thread. I'll try to find a part number.
Old 11-07-2017, 06:45 PM   #9
NSeagle78
I need to replace my volume up control on my 2006 GTO steering wheel
I need to replace my volume control button on my steering wheel it appears that I need to remove my airbag, however I donít understand when it says to us your GTO to release the holding pins / springs that are holding the air bag to the steering wheel. It says that in the original write up.
ALSO if anyone know the answer to this question. My door will not unlock (driver side). I can here the guts inside of the door working but it does not appear to be able to raise the door lock as to unlock the door. I carry needle nose pliers with me to pull the lock up so I can unlock myself from inside the car.
NSeagle78 is offline   Reply With Quote
Old 11-11-2017, 02:03 PM   #10
LFSADRG
LFSADRG's Avatar
GM part numbers are 92148567 for clock spring and 92148381 for radio controls.
LFSADRG is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
