Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > General Tech
Old 07-19-2014, 08:33 AM   #1
Well_Tester
403 build
New here. Figures is post a build thread. Even though this forum looks pretty dead.
Picked this up December 2013 and it's almost finished for the most part.
I sold my built and supercharged mustang and picked up the gto for it's replacement. I knew I wanted a gto and a 403. Just so happened I found a 05 IBM 6spd with a knock in Oklahoma on craigslist. Perfect for what I wanted and a color I wanted as well. Called the ad and went to pick it up the next morning. Car looked good so I loaded it up and headed back to texas.
Mods already on the car:
Pacesetter LT catless mids
Magnaflow mid pipe
Magnaflow cat back
K&n hot box
Pulled the motor a week after I got it home.
Here is what I have done so far:
403 kit.
-Callie's crank
-Callie's h beam rods
-wiesco pistons
Ls7 lifters
Pacesetter long tubes (came with the car)
New lifter trays, plugs, seals, dowels, etc
Ls9 head gaskets
Ported ls3 heads
Ported ls3 intake manifold
Ls2 throttle body.
Svede intake (used)
Ls3 rocker arms with trunion upgrade
Ls3 rocker stands/pedastals.
244/248 cam
Gm oil pump
Gm timing set
Slp UDP (used)
Gforce drive shaft
Monster level 4
Mgw-p
Mickey thompson et streets
Areomotive 325 pump
Brian tooley valve springs
Misc:
DIY gauge pod for wideband
Full
Bohnman led conversion and aux mod
Switched out the blue seats for a black set.
Replaced the broken front grille and paint the upper/lower grilles gloss black
06 tails
5k hids
Need to be ordered:
Spin tech mufflers to be welded into the magnaflow cat back.
ID1000's
Push rods
Battery
Alternator bracket
Well_Tester is offline   Reply With Quote
Old 07-23-2014, 02:18 AM   #2
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
Looks good. Welcome to the forum, let me know if I can help with anything.
"You'll eventually send me your diff, send it the first time, not the second or third time! This will prevent thousands of dollars going to waste." STANDARD LIMITED LIFETIME GUARANTEE IS STANDARD ON ALL BUILDS.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 07-24-2014, 02:42 PM   #3
tom's2005gto
modding all the time
tom's2005gto's Avatar
Nice build. Welcome to the forum
mods.... yep I've done them!
427 TVS2300 Killer Chiller Meziere ETP 245 Lonnie's twin pump system Hendrix-Engineering 8.8 LSPWR mini tubbed with 315's. Converted from M6 to a 4L80E built by FLT Yank SC3000
tom's2005gto is offline   Reply With Quote
Old 05-31-2015, 07:43 AM   #4
Well_Tester
2qwk,
I need a diff built. Your PMs are full. A lot of progress has been made on the car.
Car made 413 by shop A. Took it to shop B for a new tune, first one ran terrible, made 454/459. Not too bad for being an Fi motor tuned NA
Twin turbo has been installed, will be tuned on Tuesday, June 2nd 2015.
Went ahead and ordered ID1300s to run e85
Made a single gauge pod to hold the wideband and gauge pod. Didn't care on condition as I'm waiting for a bohnman a pillar pod to be made.
Bohnman splitter and gtog8ta sap grilles
Twin turbos finally arrived.
Almost finished with the install.
Old 05-31-2015, 08:31 AM   #5
Firehawk409
What turbo kit did you go with? What are you doing for suspension? Are you staying with a six speed and plan on rebuilding it or going to auto?
Firehawk409 is offline   Reply With Quote
Old 05-31-2015, 10:19 AM   #6
Well_Tester
UPP kit
****ty suspension for now. Kyb shocks/struts, BMR drag bags. Need to do research on what a good drag set up would consist of.
I'll be keeping the 6spd. Had a auto for 11 miles. Hated it and got the 6spd
When the trans goes, I'll go with a Tr6060.
When the rear goes, I want 2quik to build a rear with dss axles
403ci hybrid LS2, twin turbo on e85.
Old 06-09-2015, 12:00 PM   #7
2QWK4RU 06 GOAT
Just saw this.. looks like everything is coming together nicely.
Old 07-05-2017, 03:31 AM   #8
RoscoeL
Originally Posted by Fireehawk409 View Post
What turbo kit did you go with? What are you doing for suspension? Are you staying with crazy bulk right now a six speed and plan on rebuilding it or going to auto?
Can we get an update on the car, sounds good so far!
RoscoeL is offline   Reply With Quote
Old 06-04-2018, 09:59 AM   #9
kasmivent
Originally Posted by RoscoeL View Post
Can we get an update on the car, sounds good so far! I know that the crazy bulk supplements line sounds crazy but is quite effective
The car is amazing
kasmivent is offline   Reply With Quote
Old 10-20-2018, 10:19 AM   #10
hermank
Originally Posted by Firehawk409 View Post
What turbo kit did you go with? What are you doing for suspension? Are you staying with anvarol right now six speed and plan on rebuilding it or going to auto?
Loved the car! Is is available for sale? Really interested. Would like to know further about the car. More pics and specs.
hermank is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
