Old 03-05-2011, 12:37 PM   #1
T-bones Goat
First in the 8's
T-bones Goat's Avatar
Rear outer stub upgrade and bearing replacement
DISCLAIMER this is how I changed the outer stubs on my car. If you screw something up while following this how-to you are on your own. This redneck version may be hazardous to your health.
The first step is to remove the rear wheels. Next you will take the axles out by removing the six allen head bolts from each end of the axle. There will be a total of 12 bolts from each side. Once the axles are removed the stub nut will be exposed (next image).
T-bones Goat is offline   Reply With Quote
Old 03-05-2011, 12:37 PM   #2
T-bones Goat
First in the 8's
Old 03-05-2011, 12:38 PM   #3
T-bones Goat
First in the 8's
Old 03-05-2011, 12:39 PM   #4
T-bones Goat
First in the 8's
Old 03-05-2011, 05:59 PM   #5
Here is the link to the Discussion Thread:
http://www.gastiresoil.com/showthrea...1455#post41455
