Go Back   Pontiac GTO Forum | GasTiresOil.com > The Swap Meet > Sponsors' New Products and Product Spotlights
Old 10-01-2013, 03:33 PM   #1
New high end poly bushings for your goat.
I've worked with the manufacturer, they've produced a street version line of bushings for me. These are the best engineered Suspension bushings for the GTO. I'm having them all made in black, instead of the normal red color. These are made in Australia, not china like most competing in this market. The manufacturer has 40 years of experience and mostly caters to the race market.
I will be stocking front radius rod, rear cross member and quad eccentrics for rear camber. There are other items available such as a strut tower bushing that provides both camber and caster adjustment. This alleviates load on the front struts if using the old noltec or new whiteline camber kit. It also eliminates the binding of the front lower control arm bushing in a high caster setting.
This front radius rod bushing fully articulates and does not bind like all the other bushings on the market. In fact, it's a patent protected design. The cross member bushings are a 3 stage design and are soft enough for street, but perform like a solid would without all the noise. The rear camber bushings bite very nicely and will not loosen easily. They also have the best provision for grease retention and easy adjustment. A bushing removal tool is included to simplify the job.
Pm me for additional details. I'll have better pictures up as soon as I get the kits installed on the first few cars.
ID:	1606   Click image for larger version
ID:	1607   Click image for larger version
ID:	1608   Click image for larger version
ID:	1609   Click image for larger version
Old 10-02-2013, 12:31 AM   #2
Any idea how long it'll be until you put these up, officially?
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 10-02-2013, 04:36 AM   #3
I was going to wait 'till I install them and take some pics. They are available now if you need a set. Which were you interested in?
I wonder if there's enough interest in a group buy? Pass the word around, I'd like get these out and save everyone some money.
I hope everyone is as excited about these as I am. The design on these is awesome!
Thanks for the interest.
Old 10-02-2013, 07:21 AM   #4
And how long is that gonna be?
I'm definitely interested in the front RR bushings. Not sure who'd be willing to go in on that specific item, alone, but I can see. If the price is nice... I'd rather just get them, now.
Old 10-02-2013, 09:32 PM   #5
Good question.. I will be working on a radius rod install over the weekend if all goes as planned. I have a couple of diffs to get done, Including my own. My time will be spent on the diffs, unless a break comes in. A couple of camber kits have been spoken for and should be in the works of getting installed within the next month or so, but I don't know that they will be doing any pics.
I won't mislead anyone, the price is a bit higher than the other mainstream stuff, but it's the best available. If you've followed me, here and the other GTO forum, you know that I'm always after the best way of doing things
