Just to add to what Robo posted, this thread is something unique to this forum, as far as I know there is no other forum that has a How To section setup like this.
The reason that nobody else is allowed to post after the intial post is to keep the thread information only, this will eliminate the need to scroll through endless posts looking for what you need.
Threads can be about anything, from something as simple as changing a tire, to doing a complete drivetrain swap, just remember to include every bit of information you can think of that will help. Also if through further discussion or if a better way to do something comes along just edit your post and explain the new way to do it.
With that said post up those How To's! I know there are hundreds upon hundreds that I have read through over the years that can be posted here.
REMEMBER DO NOT POST REPLIES OR ASK QUESTIONS IN THE HOW TO THREAD!
"A fairy tale starts out once upon a time, a fishermen's tale starts out with: This is no bullsh*t." Capt Phil Harris
2004 Ghost White/Red M6
1 0F 1
Mods to date:
K&N CAI, SLP MAF Sensor, 3in SW Catback w/chambered muffs, BAER 13in brakes front & rear, TB Coolant Bypass, 160 degree thermostat, Royal Purple motor, trans, & rearend oil, black tails
