Old 09-15-2009, 10:55 PM   #1
BorlaGTO
Turbo Kit Recommendation?
Trying to find out what are peoples opinions on the APS and the GenTTR turbo kits. Currently have an 05 goat and am looking for the best possible kit. Also what would be a safe boost level on a stock engine?
BorlaGTO is offline   Reply With Quote
Old 09-16-2009, 09:53 AM   #2
Kingsize
Tech enthusiast
Kingsize's Avatar
I wouldn't go with APS definitely. The Gen TTR kits seem to be hit or miss. Honestly, if you are going to spend the money for a kit, I would say to save up an extra couple thousand and get a custom setup built. ETMC a site sponsor, (Owners name is Stephen) can build one for you. It will then be built to your specifications and will fit properly without the headaches others are having right now. Besides the APS kit is no longer available for the GTO.
2006 GTO: 500rwhp Stock bottom end LS2 with Bolt on's
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
500rwhp Dyno Pull>>> http://www.youtube.com/watch?v=z21MepuHe2g
2000 Formula: 615rwhp N/A, TH400, 9" Rear
615rwhp Dyno Pull>>> 615rwhp dyno pull N/A
9.87 Motor Pass>>>http://www.youtube.com/watch?v=CWYRSYr3nys
www.fquick.com/Kingsize
Kingsize is offline
