Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Transmission and Drivetrain
Old 04-13-2016, 01:29 AM   #1
efurtz
Leaky Dot 4 Fluid beneath Bottom of Bellhousing
I have been having to replace my clutch master cyl dot 4 fluid for a few months now. It appears to be leaking just below center of bell housing. Anyone know what the likelihood is that it's merely a nut to tighten on one or both of the lines coming from the slave cyl? OR am I needing to replace the entire slave cyl?
Help!
efurtz is offline   Reply With Quote
Old 04-13-2016, 05:07 PM   #2
More then likely it's the slave cylinder. How many miles on the car? Enough to warrant a new clutch while you are in there?
Also, you can use the F body style slave cylinder. Just requires reusing the quick connect. Simple to swap out from your stock GTO slave.
Also, highly recommend installing a 2qwk remote bleeder while you are at it. Makes bleeding the system much easier.
Old 04-13-2016, 05:08 PM   #3
moved the thread to drivetrain section.
