Old 05-30-2015, 03:20 PM   #1
02 WS6 TA
Replacement key?
What have you guys been doing with regards to replacement keys? I have a couple blanks, but my local GM dealer cant cut them. Any suggestions?
2002 WS6 M6 454 LSx
2000 Camaro SS M6
2000 WS6 M6->A4
2004 Silverado SS
2002 Grand Prix GTP sdn
2004 GTO A4
1999 GMC Slonoma
1999 "Project LS10"
1996 Impala SS
2004 Grand Prix GTP
02 WS6 TA is offline   Reply With Quote
Old 05-31-2015, 07:36 AM   #2
Firehawk409
Why wont they cut it? If they cut other keys they should be able to cut the GTO key. It's generally finding the key for a good price that is hard to do. Have you tried calling other dealers?
Firehawk409 is offline   Reply With Quote
Old 06-02-2015, 10:50 PM   #3
Steamwalker
Druid
Steamwalker's Avatar
I had mine cut at a local locksmith. Just need to find one nearby that offers "laser" cutting.
06/QSM/A4
Steamwalker is offline   Reply With Quote
Old 06-03-2015, 12:06 AM   #4
Yeah... I thought the cutting could be done anywhere with the above option.
Programming yourself is also your best bet, once the key is cut.
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 06-03-2015, 02:15 PM   #5
eric_cspan
Site Sponsor
eric_cspan's Avatar
Cutting the key isn't always that easy.
I've called about 10 GM dealers in my area and only found 1 that actually has the machine to cut our keys.
You just need to ask around or maybe get lucky with a local locksmith.
eric_cspan is offline   Reply With Quote
Old 06-06-2015, 08:32 AM   #6
02 WS6 TA
Sounds like a great time. Not! Everyone needs a spare, but the previous owner only had one key, and when I bought the car it was having the ignition tumbler/cylinder issue, and the moron kept trying to force the key to turn, so it's slightly bent- And before the inevitable happens, I need to get a spare or two. Damn, I love my F bods. LOL
2002 WS6 M6 454 LSx
2000 Camaro SS M6
2000 WS6 M6->A4
2004 Silverado SS
2004 GTO A4
1999 GMC Slonoma
1999 "Project LS10"
1996 Impala SS
2004 Grand Prix GTP
Old 06-12-2015, 09:27 AM   #7
ScoobyMike
My local ACE Hardware has a laser key cutter. I just had the ignition fail. Locksmith said the ignition runs a steel pin along an aluminum ramp and eventually the aluminum wears enough that the key won't turn. If this happens keep jiggling the key until it turns, may take 10+ minutes. Then, don't remove the key! Use the spare to lock the car.
ScoobyMike is offline   Reply With Quote
Old 06-15-2015, 04:26 PM   #8
02 WS6 TA
Interestingly enough, I had one cut successfully at the local locksmith (which had previously claimed they couldn't do it) and it works like a charm. These idiots have jobs. *Shakes head*
2002 WS6 M6 454 LSx
2000 Camaro SS M6
2000 WS6 M6->A4
2004 Silverado SS
2004 GTO A4
1999 GMC Slonoma
1999 "Project LS10"
1996 Impala SS
2004 Grand Prix GTP
Old 06-15-2015, 07:46 PM   #9
Um...
If your key won't turn, you aren't "jiggling" anything for 10+ minutes. That thing is stuck, and you're SOL. Once it starts getting stuck, but still turning eventually... it's time to fix the cylinder ASAP.
Old 06-16-2015, 02:20 PM   #10
ScoobyMike
Sorry I was not clear, what I described is a temporary fix to:
1 - get you out of a jam when it happens
2 - provide temporary fix while locksmith orders the cylinder
The 3 take-away points I had hoped to convey are:
1 - it is a design flaw and very well could happen to any GTO
2 - there is no warning, it just locks up and you are screwed
3 - All is not lost, keep monkeying with it and it will eventually turn.
It happened to me during my lunch break and I had to get back to a meeting. Took the key out at work, locksmith had to order parts. I thought I would have to get the car towed but eventually the key turned.
Once I got it home I did not remove the key again until the locksmith came back with the new cylinder. Locksmith said damage would likely have occurred if he had to remove the cylinder without the key turning. Locksmith also said he has performed this repair on 6-8 GTOs
Old 06-17-2015, 06:58 PM   #11
02 WS6 TA
Locksmith is full of crap.
2002 WS6 M6 454 LSx
2000 Camaro SS M6
2000 WS6 M6->A4
2004 Silverado SS
2004 GTO A4
1999 GMC Slonoma
1999 "Project LS10"
1996 Impala SS
2004 Grand Prix GTP
Old 06-18-2015, 05:29 AM   #12
Hate to say it, but yeah... I agree with the above.
If/when you're able to get the key out, after it potentially gets stuck, you need to leave it out. Change the cylinder as soon as possible. Don't "leave the key in," since that is when it costs more to have everything replaced. No key in, you can easily remove the cylinder. Key in, means there is more work to be done... which probably means there is more for him to charge.
