Old 03-05-2014, 03:19 PM   #1
2006GTO
2006GTO's Avatar
Flashing CEL
Just picked up a 06 M6 GTO recently. This is my first real performance car and it has full exhaust, Vararam, cam and everything to handle the cam (springs, retainer, ect)
I started it today to let it warm up and noticed i had a flashing CEL. Couldn't tell if it was running rough because the cam but the CEL did go away after 30-45 seconds. When i drove it after it went off it hasn't come back on yet.
Im seeing a lot of posts saying misfire but wasn't able to run the code while the CEL was on so im not sure.
2006GTO is offline   Reply With Quote
Old 03-05-2014, 07:59 PM   #2
elephantrider
hello
elephantrider's Avatar
you can still pull the code, even with the cel not illuminated.
standard sig
jason
elephantrider is offline   Reply With Quote
Old 03-06-2014, 12:22 PM   #3
Stoopalini
Flashing CEL means misfire. Check your spark plugs and wires. Make sure none of the wires have been burned by the headers.
2005 - M6 - QSM / Black
100% Poly / Lou's SS / SLP Rear Sway
Cluster Programming Sheet
Stoopalini is offline   Reply With Quote
