Old 12-04-2013, 10:46 AM   #51
Hendrix-Engineering
any updates?
Hendrix-Engineering is offline   Reply With Quote
Old 12-07-2013, 12:38 AM   #52
wrp
Super Moderator
Had a hard time sorting out converter problems. We've finally got a good program going with a local guy, the big converter makers do so much work for lightweight cars it is hard to get them to understand what we are doing. Local guy nailed it on the first try. Got it back on the Dyno and the damned FAST Intake gave up the ghost at 27 lbs. So we got to sort that out now, looking like a vic jr is in the future.
All bullchit is fictional (cough, cough)
wrp is offline   Reply With Quote
Old 01-16-2014, 11:59 PM   #53
wrp
Super Moderator
LSx block gets in tomorrow. Going to use the Eagle Crank and Rods I have in the 408 and add 4.125 Pistons bringing her out to 427 Ci. More importantly, the LSx will have the 6 bolt heads vice the 4 bolt heads the current LQ9 has. This will allow us to boost in the 25-30 psi range more consistently without lifting the heads.
So say goodbye 408
Old 01-17-2014, 05:48 PM   #54
wrp
Super Moderator
Go big Orange....
Old 01-17-2014, 11:00 PM   #55
-wipes away drool-
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 01-18-2014, 06:08 PM   #56
wrp
Super Moderator
Not as obvious here as when you look at it but the reluctor wheel (2 of them) have different gaps around the circumference. The wheel is loose in areas, you can tell the two pieces that had been fitted together have become unattached in areas making the assembly sort of wobbly. we'd sort of been all over the board on what the problem might be. Initially thought perhaps a burned piston. Leakdown was indecisive so we theorized that a head was lifting at higher boost. We knew we would not be sure until we had it down. Good news is that the crank, rods, pistons, and LQ9 block are in good shape. The walls are not scuffed or damaged, pistons look okay and the rods show no sign of contacting anything. Probably good thing we pulled it down when we did.
Old 01-31-2014, 04:24 PM   #57
Hendrix-Engineering
It NEVER ENDS lol...I sure don't like the 4 inch stroke for that much boost..keepin my fingers crossed for you
