Old 08-25-2013, 07:34 PM   #1
wrp
Super Moderator
Ethyl's Twins - Precision 6266s on the 408
I appreciate you guys and gals following us on the Whipple build. We had a lot of fun with the Whipple and learned a lot of things. In all, over 750,000 views were logged against the Whipple build through several of the top sites. For five years now we have dealt with the Whipple and watched our build go from a one of a kind to seeing the COPO Camaro 4.0 Liter Upgrade using much of the same things we discovered, though to a much better result. I'd have to declare the Whipple a success. We decided to go a different direction after many hours of discussions with Mike@Whipple and Brent@CBM. Both of those guys helped us many ways over the years to overcome problems and come to solutions. The result is if/when I buy a Camaro, the 4.0 liter Whipple, 170mm TB and Crusher intake will be my choice.
For now, we wanted to go a different route. SNL Performance has long been heavily engaged in Turbocharged applications and we really wanted to apply the same level of effort to a Twin Turbo Setup with as much passion as we put the Whipple package together. Steve Addison of SNL had studied the twin turbo applications found in some of the rear mount technology and the APS kits. Over the years we have helped customers with Twin Turbos replace kit designs with larger turbos, we've ported Turbos and accomplished a dozen other tweaks. In many cases constraints in the customer goals limited the outcomes. On this build Steve made a special effort to understand my goals and then set out to have my fabrication done in a manner that is consistently high in quality and easily repeatable.
We chose to fabricate the installation so that it fit the existing 2004 GTO (Ethyl). We did not want to spend a large amount of time moving brake lines and electrical fuze boxes. If you are looking for exotic and innovative ways to tuck the ABS, we were not interested in solving the problem so you won't see it emerge here. My goals are somewhat more modest than with the Whipple. I am looking for a solid performing car in the 800 rwhp range with improved reliability and that we do not have to accomplish custom fabrication for the core system components beyond the initial Turbo build.
Steve chose the Precision units that have really had a positive reliability and quality reputation in the Honda and Supra world. After several communications with Aaron at Precision we settled on two options, twin 6266 or twin 6766. I chose the 6266 giving up potential growth for a better spool. The units have a 0.81 AR with a T4 flange.
Before we could get to the good stuff we had some cleanup to do with Ethyl.
First, the Mosier pumpkin with the Wavetrac 35 spline Diff could not handle the power the Whipple made. On the fourth 60% throttle pass the Wavetrac disintegrated. There were less than 1000 miles on the unit. At our power level, Mosier/Wavetrac agreed to fix the rear end one time but advised my they could not continue the lifetime warranty. After a very amiable conversation with a gracious representative from Mosier we opted to get our money back on the Wavetrac.
Chris Nichols at GForce Engineering recommended we try a Strange S-Trac. I had considered a spool which I had run successfully at this power level on the OEM differential. However, I broke an LCA while running the spool and prefer not to use one with the IRS. If the S-Trac cannot hold I am going to an SRA.
Next, the battery relocate done when the Whipple was on the car was my first and it was not well done. SNL has taken a couple of weeks to sort out the wiring problems we encountered as we began to bolt the Twins up. We stopped the install on the Twins and went through the entire car rerouting, wrapping, and reconnecting the wiring.
We also pulled the Nitrous kit. That may have been a mistake but for now we are just going to see what the Twins can do. I know where Waco is if I need to reinstall it.
In addition to the above, one of the driving factors on the twins was to have a hood back on the car. So I have bought my eighth hood and it is waiting patiently to be installed.
Most of the Fabrication and patch up work is done. We expect to start tuning next week. Here are a few teaser pictures of the car with the mockups and in some cases, the final fabrication, in place.
All bullchit is fictional (cough, cough)
wrp is offline   Reply With Quote
Old 08-26-2013, 12:00 PM   #2
elephantrider
hello
elephantrider's Avatar
oh. my. gawd.
very nice build ! what are you guys expecting to put to the ground with that
set up ?
standard sig
jason
elephantrider is offline   Reply With Quote
Old 08-26-2013, 10:18 PM   #3
wrp
Super Moderator
Lots of the TT V8s with that size turbo are putting around 800 ish. Steve thinks it will do more. Hell of a step down from the Whipple but I will be very happy at 800/800
Old 08-27-2013, 10:24 AM   #4
elephantrider
hello
i'd be happy with 800/800. got a looooooong way to go though
standard sig
jason
Old 08-27-2013, 07:13 PM   #5
wrp
Super Moderator
We pulled the heads just to take a look inside, 5000 miles later everything looked okay.
Old 08-28-2013, 11:00 AM   #6
elephantrider
hello
oh ****, bill.. your using the dreaded lifter trays !!!
standard sig
jason
Old 08-29-2013, 08:36 PM   #7
wrp
Super Moderator
Buttoned the engine back up today. Starting to find small things displaced over time, minor delays, yet irritating. For instance we sat on the fuel rails for three months before discovering the wrong thing was sent.
Old 08-30-2013, 11:26 PM   #8
wrp
Super Moderator
Started getting into the good stuff today. Bolting the Turbo up. Everything coated and ready to install.
Old 08-31-2013, 05:42 PM   #9
wrp
Super Moderator
A little more progress today, hope to start by next weekend.
Old 09-01-2013, 11:49 PM   #10
dkrowner
nice build you have going.how come they didn't do any gussets on the manifolds or pipe from them to the turbo's?every turbo car i've had that wasn't gusseted all cracked in the long term didn't matter the make up of the metal ss or mild.just mostly street miles on the south side of chi-town for pocket change.
dkrowner is offline   Reply With Quote
Old 09-02-2013, 07:57 AM   #11
wrp
Super Moderator
Guess I don't understand the gusset.
Old 09-02-2013, 04:17 PM   #12
dkrowner
it's a piece of metal that's welded between the tubes to add strength to the manifolds so they don't crack from the weight of the turbo's
Old 09-02-2013, 05:43 PM   #13
wrp
Super Moderator
There is quite a bit of reinforcement built into the headers. If it cracks, the next owner will just have to deal with it.
Old 09-02-2013, 08:03 PM   #14
dkrowner
o
Old 09-02-2013, 09:48 PM   #15
Looking good sir.
Old 09-03-2013, 06:31 AM   #16
wrp
Super Moderator
Thanks
Old 09-05-2013, 02:27 AM   #17
erock
Peleonero
erock's Avatar
Next owner?
In my secret lab in an undisclosed location fervently working on my highly classified new mousetrap.
erock is offline   Reply With Quote
Old 09-05-2013, 04:13 PM   #18
wrp
Super Moderator
If I can find someone interested. Already figured I can part it out for enough to get a 10-11 SS Camaro
Old 09-05-2013, 06:36 PM   #19
Will you and Ethyl make it to Goatfest?
Old 09-05-2013, 10:00 PM   #20
erock
Peleonero
erock's Avatar
If I can find someone interested. Already figured I can part it out for enough to get a different pretty fat girl.
Fixed it for ya Bill.
Old 09-05-2013, 10:14 PM   #21
wrp
Super Moderator
Every time I start thinking yes, something else comes up
Old 09-05-2013, 10:59 PM   #22
wrp
Super Moderator
Stepping up the fuel deliver from the A1000 to the Eliminator. Adding Billet Controller and -12AN inlet/outlets
Old 09-06-2013, 01:06 AM   #23
erock
Peleonero
erock's Avatar
Wow nice pump!
Old 09-06-2013, 11:10 PM   #24
wrp
Super Moderator
Cool shots
Got the Oil Lines in
Starting on the Fuel System, upgrading the A1000 to the Eliminator
Ford 9 Inch is back where it belongs with the Strange S-Trac in place of the Wavetrac
Old 09-07-2013, 08:36 PM   #25
wrp
Super Moderator
Really good day today. The guys got the Turbos bolted in solid and started the fuel system assembly. Just a matter of time now.
Barring no more delays we should get a crank up video soon. Here were the major things accomplished:
Girls are all bolted up and bolted on, look kind of perky don't they?
Love how she winks at me
Downpipes bolted up with exhaust
Seriously thinking about leaving the headlights out.
