Old 05-26-2013, 03:34 PM   #1
6pointWHOA
Whoa
6pointWHOA's Avatar
Ignition switch sticks at times.
Sometimes when I go to start up the ignition sticks in the start position until I switch it off then try again with no issue. Any ideas what might be the issue and ways to fix it?
6pointWHOA is offline   Reply With Quote
Old 05-28-2013, 12:58 AM   #2
GrumpyGoat
Chivo Gruņon
GrumpyGoat's Avatar
I know this might sound unrelated to your problem but I had that same issue when my fuel pump was leaking back to the tank, when I first got my Goat it started up with the first turn of the engine, then a year later I noticed that it had to crank several times before starting up and sometimes it seemed like the ignition switch would get stuck cranking the car even if I let go of the key. I replaced the fuel pump with the LPE upgrade and it all started work like before, starts up on the first try and the ignition switch doesn't stay engaged at all. Hope this helps.
05 GTO A4, CAI, Kooks LT, Catted, Corsa Sport, Drilled/Slotted Rotors, 18/19 Beyern Type 5,
BMR strut brace, LPE fuel pump, 6000K HIDs.
Dynoed at
21st Century Muscle Cars in Addison, TX
366rwhp/387rwtq
GrumpyGoat is offline   Reply With Quote
Old 05-29-2013, 10:17 AM   #3
6pointWHOA
Whoa
6pointWHOA's Avatar
Sounds just like mine, Thanks ill check on that as soon as I can get it on the lift.
