Old 10-24-2012, 02:28 PM   #1
TheRocket
OFFICIAL: GM GenV Announcement & Platform Specifications
As some of you might know, the details to GMs new GenV V8 platform have been released.
So all the rumors can be put to rest finally and I no longer get to churn in angst when I hear you guys speculating about the new GenV engine.
I've known of these details for a couple months now but was sworn to secrecy for obvious reasons. If you guys haven't caught the details yet, there is a link below.
It's been named the LT-1 (sound familiar?).
LT-1 6.2L V8 featuring:
  • All Aluminum
  • 450hp/450tq with a broader torque band below 4,000.
  • 11.5:1 compression ratio due to a redesigned combustion chamber
  • Direct Fuel Injection
  • Variable Valve Timing (we finally get v-tec!)
  • Active fuel management
  • New head design using rectangular ports (this should be fun for all you cathedral lovers and rectangle deniers) with switched intake/exhaust valve locations.
  • New intake manifold design with plenum redesign
  • Dry sump oiling system with a cam driven oil pump
  • New electronics (i'll let you guys read about it)
Here's the link: http://media.gm.com/media/us/en/gm/n...mallBlock.html
This should be fun to see where this design takes the aftermarket companies and who takes the lead on designing some serious horsepower with this new design!
Cheers!
TheRocket is offline   Reply With Quote
Old 10-24-2012, 08:42 PM   #2
Link doesn't work
Old 10-25-2012, 12:00 PM   #3
Robofuzz, Rabs, and I were discussing this yesterday. It is a very exciting motor. It sounds great and I am really interested to see what direct injection does for it.
Old 10-30-2012, 04:34 PM   #4
PartsTaxi.com
www.partstaxi.com
PartsTaxi.com's Avatar
Send a message via Yahoo to PartsTaxi.com
From what I understand, direct injection is where they are getting the majority of the power increase while keeping fuel economy. They run RIDICULOUSLY high fuel pressures though. Will be very interested to see how the aftermarket performance companies deal with this.
Kevin
www.PartsTaxi.com
PartsTaxi.com is offline   Reply With Quote
