Old 09-13-2012, 02:58 PM   #1
doww301
doww301's Avatar
Hole drilled in mid pipe exhaust sleeve
Hi Folks: Got a question. I have an '06 a4 goat; and, on this car, I have a 3/8" round hole drilled in the tope of the sleeve where the mid pipe flange is welded. The sleeve is toward the cat on the passenger side mid pipe. This hole shoots exhaust directly up on the heat shield attached to the bottom of the car. Also, it affects the sound of the car. I only noticed this sound difference recently so my question is, is there supposed to be some device or bolt that normally fits into this hole and blocks the exhaust? If so, this makes no sense to me. I can't think of any normal reason why this hole should be there. I did a pretty exhaustive search and couldn't find anything on it which only reinforces my opinion on this. Here is a photo of the sleeve-I think it's a factory installed item. Sorry I couldn't get a photo of the hole but it's right on the top of that sleeve the flange bolts to. Any Ideas other than something dumb that somebody did before I owned the car, or is this a factory screw up that I only recently noticed? Thanks in advance for help on this!
[IMG]
Uploaded with ImageShack.us[/IMG]
2006 QSM A4
95z A4
doww301 is offline   Reply With Quote
Old 09-13-2012, 07:12 PM   #2
littlecrunch2000
littlecrunch2000's Avatar
If it was bigger, I would have guess the O2 sensor, but it's not that. Could it be an exhaust leak that has grown bigger? I know most exhaust leak holes that get bigger tend to look like a perfect circle.... I'm thinking physics here with circles being the most efficent shape for air and energy...
PANDORA - 04 TR, M6, HB CSL 19's
Show: Panasonic Strada, XM, Image Dynamic components, Infinity mids, JL Audio 8" subs in rear deck, Alpine M500 and F450, HID's, short shifter, my creation rear seat delete.
Go: P&P and milled LS6 Heads,TSP 228R cam, Ported Intake and TB, Kooks LTs, Powerbond UDP, MagnaFlow full exhaust, Svede CAI, MSD & NGK, 160*, 05-06 brakes.
Tuned by Corey at Henderson - NEW-441/410 with mods in sig --- PB: 13.42 @ 104.5 and 1.94 60' with only headers, exhaust and CAI.
littlecrunch2000 is offline   Reply With Quote
Old 09-15-2012, 02:46 AM   #3
doww301
doww301's Avatar
No, it's actually a hole
I found out that it's where a bolt was inserted into the sleeve to which the flange is welded. Why? No idea. A tech at the local GM dealer verified that this is in fact a bolt hole where a 10mm bolt was inserted at the factory. He didn't know why they did that either. Anyway, I'm gonna get a replacement bolt and loctite it in place and hope fully be done with this.
2006 QSM A4
95z A4
