Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Tuning and Dyno
Old 02-09-2012, 08:06 PM   #1
Infernus
Resident Pontiac Nerd
Infernus's Avatar
Adding timing (self tuning)
This may sound like a dumb question, but what methods do you use to add timing in HPT? I'm ordering headers in the next few days so that they'll be here in spring, and I've got a track day lined up for late April.
I've already tuned my car by myself, and I've got the AFR correction thing down, but I'm not sure how to safely add timing to the factory timing tables. I'm assuming you add one degree at a time across the board and use a histogram to track KR and pull timing in those specific cells?
BTW, I have my tune set up such that my KR attack rate is halved and the decay rate is doubled... I was getting random KR up to 7 degrees all over the place on the factory tune with several different brands of gas but no audible knock. Someone told me the cure was to do just that, since their experience was that the LS2 knock sensors are too sensitive. My high octane table is also copied over to the low octane table.
Thanks in for your help/insight.
Full time Auto Tech student, part time Auto Tech
Matco Nutswinger
05 CGM - M6/17s/Blk int - 1 of 714
Mods: Svede, Stepped Kooks/Catless mids, Bassani, HPT self tune, -168lbs
Infernus is offline   Reply With Quote
Old 02-18-2012, 05:18 PM   #2
Infernus
Infernus's Avatar
lol, considering the responses, I'll let you know how it goes once I've got it figured out...
Matco Nutswinger
Old 02-21-2012, 08:25 AM   #3
Kjhallex
Auto Swap Complete!
Kjhallex's Avatar
I don't like desensitizing the knock sensors unless you have to. I've only had to do it on a 04 gto, I just add timing to the entire table 2 degrees at a time and then stop when you see knock and retard it a degree or two depending on where your at in the rpm/load.
Go Mods: Kooks, Spintech, HP tuners Self Tuned, Auto Swap, D1 Procharger and Epp Blower Cam 612RWHP 510rwtq on 7psi, P/B: 10.89 @ 125 (04-20-13) Hopefully a little faster soon!
Kjhallex is offline   Reply With Quote
Old 02-23-2012, 09:02 PM   #4
Infernus
Infernus's Avatar
I'm going to run a few tests on the knock sensors, make sure they're torqued to spec, aren't out of spec for resistance, and respond to legit knock (tap test) before I start playing with timing in earnest. The fuel I've been buying has been from one and only one station, which the 93 tested out at 4.6% corn juice and 0% water, so the fuel seems to be of good enough quality.
Matco Nutswinger
