Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Tuning and Dyno
Old 11-22-2011, 06:20 PM   #1
HPT versus EFI Live?
I have always used npt. But, I am wondering about EFI Live due to its ability to tune the tranny. Correct?
anyone with thoughts?
Old 11-22-2011, 06:30 PM   #2
E's GTO
Real Shaker
Send a message via AIM to E's GTO Send a message via Yahoo to E's GTO
If you want to get rid of your hpt, let me know ;-)
2006 CGM
- DDM 6000k lows/fogs | Custom Magnaflow Catback with H-Pipe | Billet Pro Shifter | Functional Shaker hood| Coated Pacesetters w/ catted mids | Stage 2 Ported Intake | Ported Throttle Body | CSP NSSP Camp | Lunati Valve Springs | LS7 Lifters | .040" Head Gaskets | Powerbond 25% UD Pulley
E's GTO is offline   Reply With Quote
Old 11-22-2011, 09:58 PM   #3
ok... a bit more research and it looks like hpt will manage the tcm42 just fine.
Old 11-23-2011, 01:28 AM   #4
littlecrunch2000
littlecrunch2000's Avatar
I honestly do not know anything about the tuning process, but I do know that I am running an EFI Live tune in my car. I havent had any problems with mine. What are you looking to do with the tranny and maybe I can answer a question for you.
(most likely I wont be able to as I just take my car in and Corey does his thing and I get happy with the numbers, but I will try )
PANDORA - 04 TR, M6, HB CSL 19's
Show: Panasonic Strada, XM, Image Dynamic components, Infinity mids, JL Audio 8" subs in rear deck, Alpine M500 and F450, HID's, short shifter, my creation rear seat delete.
Go: P&P and milled LS6 Heads,TSP 228R cam, Ported Intake and TB, Kooks LTs, Powerbond UDP, MagnaFlow full exhaust, Svede CAI, MSD & NGK, 160*, 05-06 brakes.
Tuned by Corey at Henderson - NEW-441/410 with mods in sig --- PB: 13.42 @ 104.5 and 1.94 60' with only headers, exhaust and CAI.
littlecrunch2000 is offline   Reply With Quote
Old 11-23-2011, 08:04 AM   #5
^^^^ I am going to finish converting the car from M6 to A4 (already have the 4L80 in it and running) but we are going to change out the main harness and install a tcm42needed to control the 4l80e tranny. The car will need to be reflashed as a a4 car (the ecm) but I am being told that only a tech2 can be used for that (that's another issue). But the tcm42 will need programmed and codes removed or it will run in limp mode. I was told that hpt will not remove those tranny codes, but EFI will. But.... I ordered a tcm42 from pcm4less and spent the extra to have them program it and also remove the codes.
so.... for now, I don't THINK I will need EFI. Got a tech2 handy?
Old 11-26-2011, 10:29 AM   #6
littlecrunch2000
I wish I did! My life would be much easier. Sorry, Tom.
Old 12-05-2011, 07:21 AM   #7
Infernus
Resident Pontiac Nerd
Infernus's Avatar
The only advantage I know of with EFIlive over HPT is the ability to tune Duramax's. I'd assume it could get into the TCM since there's a tab for it, but I've never seen the parameters for it myself since my car is manual.
Full time Auto Tech student, part time Auto Tech
Matco Nutswinger
05 CGM - M6/17s/Blk int - 1 of 714
Mods: Svede, Stepped Kooks/Catless mids, Bassani, HPT self tune, -168lbs
Infernus is offline   Reply With Quote
Old 12-10-2011, 10:38 PM   #8
06 Blue Devil
Cookies!
06 Blue Devil's Avatar
Originally Posted by tom's2005gto View Post
Got a tech2 handy?
Tom, all the tech 2 is going to do is be the pass through module. As the real programming comes from GM service programming. You have to connect the tech 2 or the new replacement the MDI to the vehicle and then connect to a computer to do the reflash/programming. There is an advantage to using the MDI as it is computer based to start with. So as long as it had internet connection, you would be good to go.
Some mods
06 Blue Devil is offline   Reply With Quote
Old 12-11-2011, 09:48 AM   #9
Phil, thanks for calling last night. Definitely looking forward to getting this wrapped up.
Old 12-11-2011, 12:48 PM   #10
06 Blue Devil
Cookies!
Glad to help out my friend. Just let me know when you are ready to get it flashed and I will check with Bobby about when and where we can get it done.
Some mods
Old 12-11-2011, 09:40 PM   #11
littlecrunch2000
And the forum members come through again!!!!
