Old 10-18-2011, 06:11 PM   #1
2.8 rip cut snout pulley
I have played with many pulley configurations, even tried the kind with the grit impregnated in the groves, all that did was eat the heck out of a belt in one afternoon. I always wanted to try the rip cut style on the snout. The cuts are suppose to help dissipate heat and help reduce belt slip. Not sure I have enough belt gap with the smaller idler pulley to allow a 2.8, but it's worth a try.
Ordered this from leftcoast32 on Friday, it arrived today.
Some day when the goat is back and fully running, I'll give it a "spin".
Old 10-18-2011, 07:49 PM   #2
Daniel Linnett
All in MODeration
Daniel Linnett's Avatar
and once you put that on and decide you want more boost you will be asking for my 2.7 which you shoul dhave bought in the first place lol
Daniel Linnett is offline   Reply With Quote
Old 10-18-2011, 08:19 PM   #3
Kingsize
Tech enthusiast
Kingsize's Avatar
Shiny!
LOL, you SC guys.
Always searching for more power. Silly, silly I say.
2006 GTO: 500rwhp Stock bottom end LS2 with Bolt on's
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
500rwhp Dyno Pull>>> http://www.youtube.com/watch?v=z21MepuHe2g
2000 Formula: 615rwhp N/A, TH400, 9" Rear
615rwhp Dyno Pull>>> 615rwhp dyno pull N/A
9.87 Motor Pass>>>http://www.youtube.com/watch?v=CWYRSYr3nys
www.fquick.com/Kingsize
Kingsize is offline   Reply With Quote
Old 01-13-2012, 02:27 AM   #4
XSNRGY
XSNRGY's Avatar
I got a 2.6 on mine
2003 Holden HSV Clubsport R8.
Magnuson 10psi blower, 1 3/4 Hurricane 4 to 1 headers -heat wrapped - no cats single 3inch exhaust, 42lb injectors, 85mm t-body, 588/598/116LSA blower cam, HD conical springs, double row adjustable timing set, Lingenfelter ported/polished high pressure oil pump, mafless 2bar tune, K&N, exedy puk clutch, GM Ripshifter, 343x35mm front rotors and 4pots all round ( standard ), 245-19's front and 255-20's rear.
370kw & 630Nm atw
XSNRGY is offline   Reply With Quote
Old 11-08-2012, 11:43 AM   #5
radu
need moar boost
I have the same pulley in 2.9 from leftcoast32, works great.
radu is offline   Reply With Quote
Old 11-13-2012, 01:14 AM   #6
Zinn
B.O.H.I.C.A.
Zinn's Avatar
So, the LeftCoast pulleys are worth the cost? Been searching around for the best Maggie pulley for an 8-rib setup and found those guys a couple days ago.
Currently: Mostly show w/ some go
Coming soon: More go
Zinn is offline   Reply With Quote
