Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Tuning and Dyno
Old 03-14-2011, 04:20 PM   #1
SublimeZ
SublimeZ's Avatar
New guy, new dyno
I picked up a cammed 04 IBM last week. Was running rough, so took it to Brian Reckart for a little love.
Wanted to see 400, but that will have to wait on an 85mm MAF and bigger CAI. Still not bad for a street car
04 IBM 6 speed, headers and cam 411/365-system mods coming...
SublimeZ is offline   Reply With Quote
Old 03-14-2011, 06:09 PM   #2
Rabs
Go Spurs Go!
Rabs's Avatar
Yeah Brian is the man!! Beautiful color by the way!!!!
2006 Impulse Blue/Blue M6 - Brunhilda
Rabs is offline   Reply With Quote
Old 03-14-2011, 07:38 PM   #3
Nice! And welcome to the forum, BTW!
Old 03-14-2011, 09:18 PM   #4
Way to rep the '04s.
Welcome to the board!
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 03-15-2011, 06:56 AM   #5
SublimeZ
SublimeZ's Avatar
Thanks guys. So far, lovin the GTO
Old 03-15-2011, 10:38 AM   #6
littlecrunch2000
littlecrunch2000's Avatar
very nice numbers. very similar to mine if i was to add a cam. i figure i am going to go big when i do my switch though. welcome to the board and way to rep Austin!!!
PANDORA - 04 TR, M6, HB CSL 19's
Show: Panasonic Strada, XM, Image Dynamic components, Infinity mids, JL Audio 8" subs in rear deck, Alpine M500 and F450, HID's, short shifter, my creation rear seat delete.
Go: P&P and milled LS6 Heads,TSP 228R cam, Ported Intake and TB, Kooks LTs, Powerbond UDP, MagnaFlow full exhaust, Svede CAI, MSD & NGK, 160*, 05-06 brakes.
Tuned by Corey at Henderson - NEW-441/410 with mods in sig --- PB: 13.42 @ 104.5 and 1.94 60' with only headers, exhaust and CAI.
littlecrunch2000 is offline   Reply With Quote
Old 06-06-2011, 02:43 PM   #7
manuel54
manuel54's Avatar
Some strong number, like manny said way to rep us 04
TSP Torque V2 on a 112 LSA with PRC Dual Valve
Power bond 25% under drive pulley and belts
OEM LS6 Oil Pump with new o-ring
PRC stage 2.5 5.3's ls6 cnc ported heads
Cloyes Hex-A-Just Timing Set
Comp Cams Rocker Arm Trunion Upgrade
Fast intake 92mm
92mm throttle body
oil catch can, Pacesetters LT Headers,3500 Stall
440/400 at 94* on a mustang dyno, just a 5.7
manuel54 is offline   Reply With Quote
Old 01-07-2012, 04:14 PM   #8
SublimeZ
SublimeZ's Avatar
Yesterday, took the car back to Brian. Added 4" intake tube, LS2 MAF, and bigger injectors. Gained 22 whp and 10 lbs torque. New numbers, 411/365. Will try and get graph scanned this weekend. Think that's it til I can afford heads
Old 02-12-2012, 08:50 PM   #9
JayGTO
dyno
Nice! I can't wait to get mine done. I know the tune on mine is off big time. What size injectors did you go to?
JayGTO is offline   Reply With Quote
Old 02-13-2012, 12:24 AM   #10
SublimeZ
SublimeZ's Avatar
used these http://www.jegs.com/i/Accel/110/1508...oductId=749691
they flow 36 pounds at our pressures. Dropped duty cycle from 95% to 73%
