Old 07-19-2010, 02:55 PM   #1
GMPP LS9 Supercharger Kit
GM Performance Parts has released a kit that includes the LS9 supercharger, intercooler, etc. for vehicles that are running LS3 heads.
Since my GTO is running the L92 heads (which are essentially the LS3 heads), I wonder if this supercharger would clear the strut tower brace...
http://www.camaro5.com/gmpp-releases...maro-ls3-motor
Old 07-19-2010, 03:26 PM   #2
It would be interesting to say the least but at $7000 there are cheper ways to supercharge :P
Old 07-19-2010, 03:29 PM   #3
I'd rather have a naturally aspirated LS7 anyway...
Old 07-19-2010, 04:58 PM   #4
thedak
537rwhp - 501rwtq - NA
thedak's Avatar
Send a message via AIM to thedak
It will easily clear the strut tower brace.
It is 1.5" shorter than the Mag TVS2300.
The pulley placement is the same for the LS2 GTO and LS3 Camaro.
It should fit.
thedak is offline   Reply With Quote
Old 07-19-2010, 08:28 PM   #5
Thats cool...
Old 07-19-2010, 08:53 PM   #6
So, what's the difference between the LS3 heads and the LS9 heads?
Old 07-19-2010, 09:59 PM   #7
6
Old 07-19-2010, 10:01 PM   #8
LS9 heads are a little beefier for the F.I. and they also have swirl inducing wings that mix the air and fuel better.
Check it out...
http://www.vetteweb.com/tech/vemp_07...ercharger.html
