Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Tuning and Dyno
Old 05-01-2013, 09:42 PM   #1
ROSEA CARPA
BAAHBYE
ROSEA CARPA's Avatar
3.91's and a tune?
If I install a set of 3.91 rear gears on a A4 does it have to be tuned right away.... Correct me if I am wrong but all it should effect is the speedo?..
Fast and Cheap Isn't Reliable
Cheap and Reliable Isn't Fast
Reliable and Fast Isn't Cheap
ROSEA CARPA is offline   Reply With Quote
Old 05-02-2013, 11:04 PM   #2
vv8
vv8's Avatar
correct, even a tune wont fix the speedo.
12.57@105.87
2004 GTO
LT Headers
U/D Pulley
160* Thermo
SLPLM2
Tune
New setup soon H/C TVS2300 ETC. 11.40@127.61
vv8 is offline   Reply With Quote
Old 05-02-2013, 11:15 PM   #3
ROSEA CARPA
BAAHBYE
The tune will fix the speedo but what I don't know is if the gears will throw anything off and hurt the transmission?
Old 05-04-2013, 12:48 AM   #4
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
Lower gears take the load off the tranny and/or clutch. Tune will adjust optimal shifts with your combo. Just make sure you get the gears done right, the first time. Let me know if I can help with that.
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 05-04-2013, 11:02 PM   #5
ROSEA CARPA
BAAHBYE
Cool thank you! And I will.. The guy I have doing them has done 4 or 5 goats and all have turned out nice! So hope it works well for me
Old 05-05-2013, 02:48 AM   #6
2QWK4RU 06 GOAT
That should be enough rebuilds, I'm somewhere in the triple digits at this point. Use factory seals and bearings if you can, the aftermarket seals tend to leak and other bearings, including timken are a step back.
Old 05-08-2013, 06:17 AM   #7
ROSEA CARPA
BAAHBYE
Does GM have a rebuild kit and if so do you have the part number? I ordered one from g force but that was two weeks ago or more and still haven't gotten it yet.... So I may just get the GM thank you !
Old 05-08-2013, 07:36 PM   #8
2QWK4RU 06 GOAT
I have the GM parts in stock. You cant buy them in the states. The gforce kit is inferior to what I offer and use.PM me if you would like a kit. You would be taking a step backwards using the kit you mention. I'll ship tomorrow if you like. PM me.
Old 10-02-2013, 03:00 AM   #9
Canada
I need to figure out how to fix the part in hptuners that lets you actually get it to calculate the exact speed. I know my speedo is off and have no idea how fast I'm going. But right now trying to fix my vacuum leaks at the moment.
Canada is offline   Reply With Quote
Old 10-02-2013, 03:43 PM   #10
Canada
That is already done. That doesn't just fix the speedo. You have to adjust an entire table.
