Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Forced Induction
Old 08-04-2010, 07:23 PM   #1
tom's2005gto
modding all the time
tom's2005gto's Avatar
427 TVS2300 901hp 865 ft lbs.
Anyone else following Shawn's build?
WOW...... 901hp at 6300 rpm's and 865 ft. lbs of torque at 3600 rpm's. All with a set of LS3 heads and 12lbs of boost. My build is almost identical except I used ETP 245 heads and have already seen 17 lbs. with a loose belt.
Belt situation is now under control. I can't wait to get the final bugs worked out and strap this thing back down to the dyno!
mods.... yep I've done them!
427 TVS2300 Killer Chiller Meziere ETP 245 Lonnie's twin pump system Hendrix-Engineering 8.8 LSPWR mini tubbed with 315's. Converted from M6 to a 4L80E built by FLT Yank SC3000
tom's2005gto is offline   Reply With Quote
Old 08-04-2010, 08:21 PM   #2
SRMetallic
SRMetallic's Avatar
Man...I bet you are just chompin' at the bit...I know I would be...
SRMetallic is offline   Reply With Quote
Old 08-04-2010, 09:11 PM   #3
tom's2005gto
Caleb, How many miles you got on that beast now? Always loved that color combo, and you creep around in silent mode... hit the go pedal and awaken the maggie hiding under the hood and your next victim must thing "WTF?"
Old 08-04-2010, 10:05 PM   #4
Lspwr
Tubbed!!
Lspwr's Avatar
What numbers did I call out for you at Dyno day Tom . . . Lol. . .Spooky. . thats the same HP number I called yours at. . . . .
Lspwr is offline   Reply With Quote
Old 08-04-2010, 10:16 PM   #5
T-FATTY
T-FATTY's Avatar
Damn Tom i thought you went and had yours dynoed.
* 2005 GTO Pre-production built July 2004 *
* 1 of 24 BZJ Hoodscoop delete cars *
* 1 of 41 QSM/RED/M6/18s *
* Hyperblack CSL replicas *
* VX tail lights with LEDs *
T-FATTY is offline   Reply With Quote
Old 08-04-2010, 10:18 PM   #6
T-FATTY
T-FATTY's Avatar
Who's Shawn and is running a 427 with a procharger? Last time i checked you couldn't get a maggie for a GTO with LS3 heads?
Old 08-04-2010, 10:31 PM   #7
SRMetallic
SRMetallic's Avatar
I think I'm just over 28.5k miles now. I can't wait to get a little closer to work so that I can cut down on the miles that I'm racking up...It definitely is a blast though...It's no 17psi or anything , but when I drive anyone out to lunch and ask if they want to see what a little boost is like, I always get good reactions ...
Old 08-04-2010, 11:18 PM   #8
tom's2005gto
Yes sir, I do remember that.
Shawn at Virginia Speed. He has a post over on tech in the forced induction section
28.5k not bad. Do you have a boost gauge? If so, what are you seeing?
Old 08-05-2010, 07:23 PM   #9
SRMetallic
SRMetallic's Avatar
Yep...I've got the ol' boost gauge...I'm only running just a touch over 5psi...I may get ambitious and either pulley down a little or do and OD crank pulley at some point, but I'm trying to stay on the safe end for now ...
Old 08-05-2010, 09:18 PM   #10
tom's2005gto
^^^^ better safe then sorry. You've got your self a sweet ride there!
Old 08-05-2010, 10:45 PM   #11
SRMetallic
SRMetallic's Avatar
Thanks man...I agree...as much fun as it would be to build up a motor right now, it isn't really in my short term plan ...
Old 08-06-2010, 06:30 AM   #12
BillsMafia
"Post Whore" Moderator
BillsMafia's Avatar
I thought the same thing... I've been waiting to see Tom's results. Lol.
Tuned by Matt@SNL: 443rwhp/427rwtq - SOLD
BillsMafia is offline   Reply With Quote
