Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Body, Appearance, Detailing
Old 01-04-2011, 02:38 PM   #1
LED's for the tail lights How To Discussion
How much did all the bulbs, etc. set you back? And if you were to install the resistors, where would they need to be installed?
Edit: Just looked up the prices on your links. This little mod is pricier than I originally thought, but ultra cool!
Old 01-04-2011, 02:55 PM   #2
I spent $184 for everything including the resistors and mount brackets. I have been told that you can mount the mount bracket to the bumper bracket just below the tail light harness in side the trunk
Old 01-06-2011, 07:16 PM   #3
Here is the link back to the original thread:
http://www.gastiresoil.com/showthread.php?t=2309
Please discuss here and not in the orginal How To thread.
Thank you,
Randie
Old 05-29-2013, 01:51 PM   #4
kookiemonster
oklahoma goat
kookiemonster's Avatar
Send a message via Skype™ to kookiemonster
I know this is an old thread but i just did mine and have the resistors in but when i put the car in reverse of brake my radio goes to complete static
Trixy 05 pbm m6
Mods- kooks ss longtubes, e-cutouts, bc coilovers, ls7 clutch, tick master, ss cluch lines, stage2 texas drivetrain performance t56, spintech axleback, vararam intake, proxes mgw shifter, and a slipping stock lsd. wavetrac, gears, harrop, and awh axles waiting for install.
kookiemonster is offline   Reply With Quote
