Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > How-To's
Old 02-08-2014, 05:08 PM   #1
Robofuzz
Robofuzz's Avatar
Send a message via AIM to Robofuzz
Fixing Sagging Rear Diffuser (aka Australian Butt Lift)
As promised, I came up with a simple solution for the sagging rear diffuser. On 2005-2006 GTO's the problem presents itself like this: (Thanks, Rabs, for the pics since I forgot to take before pics of mine.)
As you can see, the problem is the black plastic diffuser is sagging at the rear flap that allows you access to the trailer hitch mount points.
Here's the materials I used to solve the problem. It's 1 1/4" x 1/16" flat aluminum and plastic push pin retainers for a 5/16" hole (similar to what holds your radiator cover on).
I first took out the push pin retainers that hold the little flap closed. With the flap now open, I measured and cut a piece of the flat aluminum to fit just inside the flap. I then drilled 3 holes in it, starting with one in the center and then one on each side about a half inch in from the edge:
Using the holes I drilled, I clamped the flat aluminum to the top side of the flap and drilled through the plastic to match the holes in the aluminum. Then I simply secured the aluminum using the plastic push pin retainers pushed through from the underside:
Then you simply close the flap and put in the factory push pin retainers that hold the flap closed. If the flap still sags a bit in the middle, simply open it and slightly bend the aluminum so that the diffuser is even with the rear valence. From the underside (if you care), you only see the heads of the three new pushpin retainers.
And here's the result:
Click image for larger version
ID:	1653   Click image for larger version
ID:	1654   Click image for larger version
ID:	1655   Click image for larger version
ID:	1656   Click image for larger version
Robofuzz is offline   Reply With Quote
Old 02-23-2014, 03:09 AM   #2
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
Very nice. That sag is irritating. This is a good time to throw out the boat anchor underneath and put one of my delete kits in. Let me know if you want one, I'll ship it out Monday for you
"You'll eventually send me your diff, send it the first time, not the second or third time! This will prevent thousands of dollars going to waste." STANDARD LIMITED LIFETIME GUARANTEE IS STANDARD ON ALL BUILDS.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 02-23-2014, 09:25 AM   #3
Robofuzz
Robofuzz's Avatar
I installed your delete kit also. I put a couple of pictures on your thread in Sponsor Specials and on the Facebook group. Really nice quality kit and EASY to install!
Old 02-23-2014, 08:42 PM   #4
2QWK4RU 06 GOAT
Ooops, forgot...lol. I need to make a sag kit by robfuzz
