Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Engine Tech
Old 03-16-2015, 10:08 PM   #1
Firehawk409
Rearmain seal leaking
It looks to be leaking but not much. I'm sure most of it is from my slave. I'll soon be replacing my clutch and might as well replace it to. So, my question is, do I just replace the seal or the whole housing? It's an 05 GTO.
Firehawk409 is offline   Reply With Quote
Old 03-18-2015, 09:35 AM   #2
Firehawk409
Alright guess no one is here.
Old 03-18-2015, 09:13 PM   #3
I always replace the cover with seals and bolts when I pull the tranny of a car. I think it's like $48 for the kit
Old 03-19-2015, 07:21 PM   #4
mwritter
I agree, replace the whole cover. Make sure you install it with the alignment tool.
mwritter is offline   Reply With Quote
Old 03-19-2015, 09:04 PM   #5
geddy2112
I just did this. I bought a new rear cover with bolts and gasket off amazon. The new cover came with a clear cover that you line up with the crankshaft snout and simple slide it in place. I used a little tiny dab of the Right Stuff sealant around the corners of the oil pan.
geddy2112 is offline   Reply With Quote
Old 03-19-2015, 11:40 PM   #6
Firehawk409
So the one on amazon comes with the alignment tool? I'm guessing i need to pay special attention to the oil pan gasket? Im having flashbacks from my old lt1. Lol
Old 03-20-2015, 07:45 AM   #7
Informative thread right here. Since my '04 has finally shown signs of leaking, the past few months. Nothing too drastic, but I know what to be on the lookout for.
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 03-20-2015, 09:03 AM   #8
geddy2112
Not an alignment tool but a plastic cap that is the size of the crankshaft flange. The cap is already sitting inside the rear main seal when you open the box. so you just position the cap on the crankshaft flange and slide the whole engine cover to the back of the block. As you slide the cover back, the cap will remain on the crankshaft and you just take it off.
Amazon.com: Genuine GM 12639250 Crankshaft Oil Seal Housing, Rear: Automotive Amazon.com: Genuine GM 12639250 Crankshaft Oil Seal Housing, Rear: Automotive
Old 03-20-2015, 11:54 AM   #9
mwritter
Great video on the subject that will help you line up the rear cover so you're less likely to have future leaks.
https://www.youtube.com/watch?v=mzkD1_b_LAs
Old 03-20-2015, 02:19 PM   #10
Firehawk409
Is that the kit you bought? The other ads on amazon state they come with bolts and seal. This one doesn't say that. I see a Dorman kit and an APDTY kit.
Old 03-20-2015, 09:02 PM   #11
geddy2112
Yes, this kit comes with everything. New rear engine cover, new cover to block gasket, new bolts and new rear main seal already installed on the cover.
if you watched the video, towards the seal install, the installer took out an uninstalled seal that has that plastic center cover that goes over the crank. that is the cover i was describing. The differences with the Amazon link is the rear main seal is already installed on the engine cover, so you just slide the whole engine cover with the seal and gasket over the crank shaft and follow the torque sequence. No need for that rear engine cover centering tool.
Old 03-20-2015, 11:32 PM   #12
Firehawk409
Aaahh.. Okay. Sounds good. I'll go ahead and order that kit when it comes time.
Thanks for all the info and help.. My ole lt1 just has me a bit spooked when it comes to oil leaks and gaskets/seals. Good info and the right tools definitely made the job easier and leak free when it came to the lt1. Any corner cutting and you got a mess on your hands.
