Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Engine Tech
Old 05-26-2013, 06:35 PM   #1
afgun
Heh. You said "member"
Send a message via Yahoo to afgun
"Check Engine Oil" message today
Eek! Starting up at IHOP this morning the car sounded weird and the display said "Check Engine Oil". Frowning, I shut it off, checked the oil level (full, just changed it a week ago) and scratched my head. Started it up, same symptoms, so I thought I'd pull down the street into a gas station. I pulled out of the parking lot, accelerated, and then the sound went away and the check engine oil message went away. The only thing that I can think of is that there was a clog or cavitation in the oiling system that the higher RPMs of actually driving popped loose...
Your thoughts?
'06 PBM Converted to A4
Kook's LTs, Magnaflow cat-back, Vigilante 3000, SNL v.3 cam, Ported FAST92, Ported TB, SNL CAI & MAF, Reckart tune, 421HP
afgun is offline   Reply With Quote
Old 05-26-2013, 08:18 PM   #2
Wish I could offer more advice, but I would say, first and foremost...
DON'T DRIVE IT!
Not until you see if there's anything else going on.
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 05-26-2013, 10:22 PM   #3
You sure it wasn't the oil change reminder?
Old 05-27-2013, 05:14 PM   #4
If it's the "Service Engine Oil" alert, that's one thing.
If it says "Check Engine Oil," then don't drive it until you find out what is wrong, if anything.
Old 05-28-2013, 10:37 AM   #5
afgun
It was definitely check, not service. And like I said, it's been fine since. Like I had a clog or cavitation of some sort. *sigh*
