Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Engine Tech
Old 06-02-2013, 09:03 PM   #1
HSV got some Hinson motormounts
While we were doing the other work, we opted to replace the factory motor mounts with a set of stock height rubber core from Hinson. Can definitely tell a difference. Car actually seems to be a bit more responsive. Solid feeling, but not any more noise, etc.
Worthwhile and glad I used these.
tom's2005gto is offline   Reply With Quote
Old 06-02-2013, 10:45 PM   #2
Robofuzz
Robofuzz's Avatar
Send a message via AIM to Robofuzz
Good to hear the review. I am on first gen Noltec mounts and I'm not real comfortable with staying with them. I wish Hinson would hurry up and make a tranny mount.
Robofuzz is offline   Reply With Quote
Old 06-10-2013, 01:56 PM   #3
E's GTO
Real Shaker
Send a message via AIM to E's GTO Send a message via Yahoo to E's GTO
How hard is to swap out the motor mounts?
2006 CGM
- DDM 6000k lows/fogs | Custom Magnaflow Catback with H-Pipe | Billet Pro Shifter | Functional Shaker hood| Coated Pacesetters w/ catted mids | Stage 2 Ported Intake | Ported Throttle Body | CSP NSSP Camp | Lunati Valve Springs | LS7 Lifters | .040" Head Gaskets | Powerbond 25% UD Pulley
E's GTO is offline   Reply With Quote
Old 06-10-2013, 06:36 PM   #4
Hard for me to really say. We did them while doing a header install. So we didn't have any exhaust in the way to deal with.
mods.... yep I've done them!
427 TVS2300 Killer Chiller Meziere ETP 245 Lonnie's twin pump system Hendrix-Engineering 8.8 LSPWR mini tubbed with 315's. Converted from M6 to a 4L80E built by FLT Yank SC3000
Old 06-10-2013, 07:40 PM   #5
elephantrider
hello
elephantrider's Avatar
easiest way is to remove the mount bracket from the side of
the block 1st ( while supporting the engine static ), then remove
the mount from the bracket - then reverse for install.
standard sig
jason
elephantrider is offline   Reply With Quote
Old 06-10-2013, 08:03 PM   #6
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
Keep me posted on any developments on these, I am wanting to replace my early noltec units.
Are yours starting to seperate?
"You'll eventually send me your diff, send it the first time, not the second or third time! This will prevent thousands of dollars going to waste." STANDARD LIMITED LIFETIME GUARANTEE IS STANDARD ON ALL BUILDS.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 06-10-2013, 08:47 PM   #7
I had 2nd gen noltecs on "money pit" and changed to scss shorties for additional hood clearance.
Old 06-11-2013, 12:28 AM   #8
2QWK4RU 06 GOAT
So these smoother? Close to stock nvh?
Old 06-11-2013, 07:42 AM   #9
Car feels firmer, solid. But does not shake and shimmy like money pit with the solid mounts. Seems to respond to the throttle better then stock.
Old 09-25-2014, 09:57 AM   #10
Jontall
Tom, I thought Hinson mounts were urethane?
Jontall is offline   Reply With Quote
