Go Back   Pontiac GTO Forum | GasTiresOil.com > G8 Forum > G8 Discussions
Old 01-12-2012, 10:54 AM   #1
Daniel Linnett
All in MODeration
Daniel Linnett's Avatar
Twin Turbo 418 almost complete
The time came to make a change away from the TVS2300. I had broken 2 jackshafts and Magnuson said they would not warranty another. I talked with a Grrrr8.net board member and purchased his Twin Turbo STS upgraded kit to see if not only I could make more power but do so without part breakage. I sold the TVS to a guy in Dallas and I installed it on his car for him. He intern paid for the Turbo kit to be shipped down to me. After much pain installing the kit due to aftermarket exhaust and headers I came up with a solution to make it work. I still have to clean up some oil lines and some wireing to make it truly look clean but I want to get the car up and running and get her tuned.
I drove to ETMC and we were getting her ironed out. The car was hitting a wall at 6200 that looked like it was dropping a cylinder. I hoped for the best but I knew in my heart the engine probably needed a refresh. We pulled the valve covers and inspected the springs hoping that was all it was. NOPE, we did a compression test and found all cylinder were 140/150 but that number 7 was 100 and 5 was 120. Like I said I knew the motor was hurt.......when the shaft broke at the ECS we pulled the plugs and notice 7 was destroyed. I put new plugs in and the car ran and drove without missfiring or anything like that.
Well onto where we stand now. The car is at ETMC because I am tired of doing the labor on my car at this point so I am letting them pull the motor and have it refreshed. They are pulling it apart tomorrow supposedly and we should find out what the exact issue is. Then it will be dyno time and shooting for 800rwhp at 15psi and get that 9 second pass.
Daniel Linnett is offline   Reply With Quote
Old 01-12-2012, 11:00 AM   #2
Daniel Linnett
All in MODeration
THIS
CAUSED THIS
So now This
Old 01-12-2012, 11:03 AM   #3
Daniel Linnett
All in MODeration
exhaust note video was before tune day when we found compression issue.
She put down 680rwhp at 11psi before we found the compression problem. After that each pull the car made less hp so we knew we had to search for the issue. Glad we found it. If I was not so burned out on the car I would have pulled it my self and save several hundred dollars but at least I know it will be done right.
Old 01-12-2012, 11:07 AM   #4
Robofuzz
Robofuzz's Avatar
Send a message via AIM to Robofuzz
Isn't this the second motor in your G8 already? I hope it's not something major.
Robofuzz is offline   Reply With Quote
Old 01-12-2012, 11:09 AM   #5
Daniel Linnett
All in MODeration
Stock motor was swapped for the 418, and now I have to refresh the motor. Not a new engine or full rebuild just a little work.
Old 01-18-2012, 07:43 PM   #6
2QWK4RU 06 GOAT
CONSULT WITH ME, LAST.
2QWK4RU 06 GOAT's Avatar
Are any aussie tt kits available? I know aps had some at one point... Good luck with the build. If you need any custom plumbing, let me me know if I can be of help.
2QWK4RU 06 GOAT is offline   Reply With Quote
Old 01-19-2012, 06:22 AM   #7
Daniel Linnett
All in MODeration
Aps will not sell to states anymore for g8 or GTO. GenTrr will and I am the only US distributor. I got the sts kit about 2k cheaper then even I can get the genttr kit at wholesale. Sts kit is complete on my car and motor seems to be fine. We are putting in new bearings and better oil pump just as insurance. Should have back together in week or two. Block will go to machine shop to be inspected.
Old 01-26-2012, 11:12 AM   #8
Hendrix-Engineering
Im severaly disipointed in magnason,im ready to do something different the new owners are running that company in the ground.I wish you luck on the new build i dont think you can go 9s on turbos alone but i hope you reach your goal.If you need anything from us give me a call.
Hendrix-Engineering is offline   Reply With Quote
Old 01-26-2012, 11:40 AM   #9
Daniel Linnett
All in MODeration
I was severly pissed off at magnuson thats why i switched. My choice was between twin 62 or a F1 procharger. The procharger was going to cost me about 1000 more so I had to choose my pocket book. I still have a 100 shot in reserve and a 2step to get off the line. East Texas Muscle Cars is cleaning up the engine carnage that the Shaft Breaking caused. Stephen seems to think that we will easlily be over 800 without the nitrous and with a 2step should launch off the line just fine. I am expecting 9.7@144
Since I am flat broke after the motor fiasco I dont have the ability to even take you up on discounted offers I would love a larger TB but I cant afford it. You have always been good to me Thomas and I will continue to send business your way. Let me know what FI you are going to be pushing and I will get the word out.
Old 01-27-2012, 09:18 AM   #10
Hendrix-Engineering
Thanks,you wont need a tb with the turbos i dont think its worth the money,on maggies its much needed but thats really about it.You may need some axles tho lol!
Old 01-27-2012, 11:22 AM   #11
Daniel Linnett
All in MODeration
you would have to work some serious magic
Old 02-19-2012, 07:04 PM   #12
Hendrix-Engineering
update
Old 02-19-2012, 08:32 PM   #13
Daniel Linnett
All in MODeration
Sending motor back to Texas speed. Cylinder bores went egg snapped and lost compression on two cylinders. Going to go with iron block instead. Just a 408 @15psi
Old 02-19-2012, 09:22 PM   #14
Hendrix-Engineering
Man will it ever end,good luck
Old 02-20-2012, 09:34 PM   #15
Daniel Linnett
All in MODeration
Crap happens. I didn't have to pull the motor but decided I wanted it perfect.
Sent from my iPhone using Tapatalk
Old 03-03-2012, 06:47 PM   #16
Hendrix-Engineering
update
Old 03-03-2012, 07:47 PM   #17
Daniel Linnett
All in MODeration
Texas Speed said iron 408 should be ready in a week or so. Hoping to have car running for ETMC track rental on 25th
Old 03-28-2012, 06:47 PM   #18
Poolshark1321
Poolshark1321's Avatar
Damn, it never ends does it? GL with the new build... look forward to some video when its done!
Poolshark1321 is offline   Reply With Quote
