Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Nitrous Systems
Old 09-09-2009, 06:18 PM   #26
Skizzy
Nitrous Whisperer
Skizzy's Avatar
Send a message via AIM to Skizzy
Originally Posted by jworl View Post
Chris from Nitrous Outlet? Spoke with you today regarding the installation. Thanks for the help! Shouldn't be too bad.
Yes sir i'm Him
Info can be located @ www.fquick.com/Skizzy
Skizzy is offline   Reply With Quote
Old 09-13-2009, 05:54 PM   #27
jworl
poor 04 owner
Send a message via AIM to jworl Send a message via MSN to jworl
Finished all the wiring last night. I'm not going to lie... I would've been totally lost without a couple friends. lol.
They ran the TPS and tach wires from the windows switch to the PCM. Everything looks great. Some of the wiring with the relay was messed up initially, but once that was taken care of, all was well.
Bottle heater pressure switch is set to 1100psi.
On Friday, I'm gapping/swapping in the NGK TR6 plugs. What should I gap them at?
On Saturday, we're hitting the dyno. Currently, the 150 shot jets are in. What AFR should I shoot for? I was thinking 11.5-11.7. Figured the specified jets should be close. One up/down at the most. For timing, I'm currently running 20-21* WOT. Figured that would be a good place to start for this size shot. Should it be pulled more though? If the rule of thumb is 1* per 50 shot, and people are running 26-27* of timing N/A, 20-21* should be plenty safe.
jworl is offline   Reply With Quote
Old 09-29-2009, 07:40 PM   #28
scraggy
For those who might search later, do not use the PCM for the TPS signal, we had to move it to the wire coming off of the sensor to get it to work correctly.
2005 MBM GTO367whp/372tq PB SO FAR: 1.99 60ft 8.63@83.89 mph 1/8 ON Street tires, OTRCAI, Drag bags
MODS : DIY OTRCAI,Stainless Works LTs, X-pipe, Drag Bags, B&M Shifter/LSS combo with factory knob, CAGS delete. Innovate LC-1 wideband, tuning of some sort soon.
scraggy is offline   Reply With Quote
Old 10-06-2009, 09:39 PM   #29
Trents_goat5.7
Trents_goat5.7's Avatar
Mind posting a link to the setup you ordered?
http://www.tyedesign.com/ETG/trent_sig_NEW.jpg
Trents_goat5.7 is offline   Reply With Quote
Old 10-06-2009, 09:45 PM   #30
Trents_goat5.7
The NGK TR6 plugs should already be gapped if I'm not mistaken.
Old 10-06-2009, 09:51 PM   #31
Daniel Linnett
All in MODeration
Daniel Linnett's Avatar
tr6 come gapped at .4 need to gap to .35
Daniel Linnett is offline   Reply With Quote
Old 10-08-2009, 10:28 AM   #32
Skizzy
Nitrous Whisperer
Skizzy's Avatar
http://www.ls1gto.com/forums/showpos...95&postcount=9
Old 10-08-2009, 10:53 AM   #33
csurane24
csurane24's Avatar
^^^ The "other" site
Mods: Kooks 1 3/4", catless mids, Borla, K&N cai, 228R cam, Dual springs, Chromoly push rods, 243 heads, double roller timing set, 25% UDP, 3000 stall, trans cooler, Walboro 255, 8.1L fuel bucket, FAST fuel rails, stage 5 4L60E from RPM, tuned by Justin at Modern Muscle, and a suprise at the end.
csurane24 is offline   Reply With Quote
