Go Back   Pontiac GTO Forum | GasTiresOil.com > Regional Forums > Texas > ACGH (Alamo City Goat Herd)
Old 03-16-2011, 05:42 PM   #1
S.A. GOAT
Blown
S.A. GOAT's Avatar
DDM Tuning-HID Kit Slim Ballast
Which kit did you guys get? 35W or 55W?
How was the install? Need any adapters or harnesses, or just the slim kit?
LQ9 Forged Iron/D1SC/L92/L76/Custom Aeromotive Fuel System/Snow/Viper Spec Stage IV trans/RPS Stage III/634/559 at 12psi - SD Tuned by Nelson Performance
S.A. GOAT is offline   Reply With Quote
Old 03-16-2011, 08:05 PM   #2
dantheman
Best Moderator Ever
dantheman's Avatar
Send a message via AIM to dantheman Send a message via MSN to dantheman Send a message via Yahoo to dantheman
ive got the 55w in my gto and my lexus and ill be putting one in my gf's gto as well. in my gto for 2 years now and my lexus for 2 weeks. working great as usual.
nothing else needed with the slim kit. its only a 6amp draw at fire up and 2.5-3amp constant while running. the factory wiring is perfectly suited for this level.
from what i hear the 55w is on a 6week backorder. everything is plug and play except for cutting the hole in the headlight housing cap. but a 1in hole saw or drill bit makes quick work of it then just a bit of rtv to help seal the boot to it.
here is my install thread. its on the "other" site
http://www.ls1gto.com/forums/showthread.php?t=278615
SNL 346, AFR 205s, TSP 233/239, SLP pulley, MTI TB, poolshark ported intake, SW LT's, Monster Stage 3, pedders street II, BMR bar & bags, stiff drivetrain mounts, VMR V710s 18in staggered in hyper silver.
dantheman is offline   Reply With Quote
Old 03-16-2011, 09:09 PM   #3
What kit do you need from http://www.ddmtuning.com?
Old 03-16-2011, 09:18 PM   #4
MannyLobo
HGH Optimist
MannyLobo's Avatar
Send a message via AIM to MannyLobo Send a message via Yahoo to MannyLobo
I have the 35w kit, myself. Still A LOT better lighting than the stock bulbs. I had matching lows and fogs, and I could see out front very well.
If you end up buying 55w, be sure to buy a wiring harness. And no matter which kind you get, be sure to pull your DRL fuse located under your hood. Everything else is pretty straightforward.
Selena: 2004 QSM/Black A4 - Bone Stock: 13.591 @ 102.10 (60': 2.030) - [Street Tires] - [3/26/10]
Show: Interior/Exterior LEDs, 35W 5000K HIDs, Clear Side Markers, '05/'06 Hood, '06 Tails, Cut '04 Bumper with PFYC Rear Inserts
Go: LPE Intake, Ported TB, Ported LS6 Intake, Custom '05/'06 Exhaust with Dynomax Bullets & Stolen Fox H-pipe
Whoa: Powder Coated '05/'06 Brakes, Russell Stainless Lines, Drilled/Slotted Rotors
Chelsea: 2005 GMC Yukon SLT - Deep Blue Metallic --- The New Daily
MannyLobo is offline   Reply With Quote
Old 03-16-2011, 09:34 PM   #5
S.A. GOAT
Blown
S.A. GOAT's Avatar
was thinking the 35W HID Kit Slim Ballast
Old 03-16-2011, 09:36 PM   #6
Yes but which bulb kit(s) do we need? H11?
Old 03-16-2011, 09:37 PM   #7
S.A. GOAT
Blown
S.A. GOAT's Avatar
great info. thanks a million.
Old 03-16-2011, 09:48 PM   #8
S.A. GOAT
Blown
S.A. GOAT's Avatar
crap. Good question. I was going to get the H1. Guess I'll research some more.
Old 03-16-2011, 09:59 PM   #9
Lancer-AM
The All-Seeing Mod
Lancer-AM's Avatar
H11 for the lows. Depending on how good the kit is, you shouldn't have to pull the DRL fuse. I have installed two of the 35w kits I sell in GTO's and both worked with no flicker with the DRL's on.
2010 Mazdaspeed 3 Tech
Stratified S-OTS Stg2 93
JBR Power Path Stage 3
JBR 70A RMM
Autotech HPFP Internals
CP-E TMIC
Sure Short Shift Plate
ABT Slotted Rotors
Cobb 3" Downpipe
Swift Spec-R Springs
JBR Rear Sway Bar
Lancer-AM is offline   Reply With Quote
Old 03-16-2011, 10:10 PM   #10
Forgive my ignorance but you would need to order two H11 kits for the low beams, correct? And two kits for the high beams and also two kits if you wanted to do the fogs?
Old 03-16-2011, 10:13 PM   #11
rebinc
Legal in 41 States
rebinc's Avatar
Each kit normally includes a pair, so only one kit of H11.
One of DDM ballasts finally took a **** two weeks ago, 2.5 years isn't bad for $50.
rebinc is offline   Reply With Quote
Old 03-17-2011, 12:39 AM   #12
MannyLobo
HGH Optimist
MannyLobo's Avatar
REB is right, one kit consists of a pair.
H11 for the lows, H9 for the highs, and 9005 for the fogs. From what I've read, the highs aren't really necessary. HIDs weren't made to turn on and off, so your highs would rarely be used. Unless you're a dick, and drive around with your high beams on. Haha.
(FYI: Your fog lights will be reverse polarity, as well.)
Old 03-17-2011, 12:47 AM   #13
Zdeuce4
I do work
Zdeuce4's Avatar
Send a message via AIM to Zdeuce4
i ordered mine a week and a half ago. 35 w 5000k. i hate blue hids. i like pure white. no yellow no blue
on the drl comment. i've heard the fuse needs to be removed not because of flicker, but because the drls pull a lower wattage from the light..
do gtos use the his or lows for drls?
I do Workhttp://i178.photobucket.com/albums/w266/Zdeuce4/GTO1-1-2.jpg
Zdeuce4 is offline   Reply With Quote
Old 03-17-2011, 01:59 AM   #14
MannyLobo
HGH Optimist
MannyLobo's Avatar
I thank you, sir, for HATING blue HIDs. That is what caused my first accident in the GTO. Couldn't see a guy hauling towards me, and I jumped a curb to avoid being T-boned.
Some people don't realize how much pure white light shines better and safer. I got the same temp and wattage as you, so I know what yours look like.
You're also right about the DRL fuse. The GTOs use the lows, and the HIDs don't like being run all day, especially at that lower power. You're sure to run the HIDs out quicker, if you leave them on and/or turn them on and off too much.
Old 03-17-2011, 09:08 AM   #15
ccalhoun29
Hey do you have the part number for this kit ?
A4 with a few mods. putting down 450/437.Through catless mids with axle back Flowmasters.Tuned by Matt @ SNL.....
ccalhoun29 is offline   Reply With Quote
Old 03-17-2011, 01:28 PM   #16
Lancer-AM
The All-Seeing Mod
Lancer-AM's Avatar
The lower wattage from DRL's will cause some kits to flicker. Running them all the time isn't really a problem, HID bulbs have a higher life expectancy than standard halogen bulbs. Running them in your Highs doesn't do much good unless you run a 55w kit on your highs, putting a 35 watt kit in your highs would produce the same ammount of light as your lows it just wouldn't be focused because of no projector lens.
JBR 70A RMM
CP-E TMIC
ABT Slotted Rotors
Cobb 3" Downpipe
JBR Rear Sway Bar
Old 03-17-2011, 02:52 PM   #17
dantheman
Best Moderator Ever
dantheman's Avatar
from my order email
DDM55W.H11.5000K
DDM HID Kit, 55W, H11, 5000K
Wattage: 55 Watt (+$10.00)
Bulb Color: 5000K
Bulb Type: H11
my DRL fuse has been out since i put them in because of flickering. i hate the look of DRL anyway so it doesnt matter. i always run with my parking lights and fogs during the day and click on the HIDs at night.
they have been in the car since dec 09 and havent had any problems even after being in a front end wreck that destroyed the headlight, the HID survived.
